254 eight cylinder ...
254 eight cylinder oil pan
3 Users
(@53jet)
Trusted Member Registered
I have a rebuilt 1947 straight eight with the flat oil pan. Seems like I heard someplace you can switch to the stepdown style pan fairly easily. Is it true you can swap oil pickups and pans ?
Posted : 19/06/2023 10:44 am
(@Dany Spring)
Not true.
Posted : 20/06/2023 2:20 am
(@adamb)
Roger, in 1948, the Eight block was redesigned to fit into the new Stepdown chassis. the rear flange for the oilpan was widened considerably for a deep rear sump pan. Also the bellhousing bolt pattern on the Stepdown eiight is different from the 47 and earlier cars.
Posted : 20/06/2023 6:59 am
(@53jet)
Thank you Ken
Posted : 20/06/2023 3:28 pm
