1935 Hudson 8 trann...
1935 Hudson 8 tranny removal.
2 Users
(@John Knox)
Hello,
I am trying to remove my tranny for an inspection because it pops out of second.  1935 straight 8 Hudson.
I am leaving the engine in the car.  I removed the starter and the bell housing bolts.  I removed the cross member bolts.  I loosened up the clutch linkage shaft.  Speedometer cable is off.  Drive line disconnected.  Engine is supported.  I can jiggle the tranny and bell housing and can see motion between it and the clutch.  I jiggle and jiggle and say every bad word I know...but I can't get the tranny and bell housing to break free and slip off.   I am thinking there is a trick to get the tranny to slip off....maybe spinning the clutch as I pull back on the tranny?
Thanks,
John
Posted : 21/12/2022 3:06 pm
(@obermeier)
Honorable Member Registered
Have you ;removed the  pedal links that slip into a hole in the cross shaft?   A bit of a circus to remove the pedal  support bracket and jiggle the  shafts around. I assume you mean  by "cross member bolts" you are referring to the 5/16"  bolts that hold the rear engine mount in place?  You will have to jack the engine up quite a bit.
Posted : 22/12/2022 12:53 pm
