1933 HUDSON 8 CAMSH...
1933 HUDSON 8 CAMSHAFT AND THROW OUT BEARING SEAL NEEDED
4 Users
(@Tom Brintnall)
I am in the process of re-building a 33H 254ci engine and need a good camshaft, cam bearings  and a throw out bearing seal. Is the cam shaft compatible with any from 30 to 33 H ?
Thanks in advance, Tom.
Posted : 29/10/2022 1:09 am
(@jadebee)
Estimable Member Registered
Hudson numerical list indicates all cam bearings are the same for Hudson 8 and Terraplane 8, 1930, 31 32, 33 and T 8.
I seem to recall 1932 lifters were changet to shoe from rollers.  They advertized about 10 % more HP.
The hardning of cam lobes for friction with 3 inch radius lifter contact surfaces must have been reason why 1930 and 1931 H 8 cams are listed with same number 33040.
Posted : 29/10/2022 9:28 am
(@jadebee)
Have not found 33 H 8 cam # yet.
camshaft 43804 for 33 Terraplane, 1934-35  Hudson, may help.
Posted : 29/10/2022 9:59 am
(@Tom King)
 From the 30-39 Master parts book. There is no interchange shown for it.If you have a cam that is worn you may try Delta Cam in Tacoma, WA.They can hard face and regrind your cam if they have the tooling
Posted : 30/10/2022 1:28 pm
(@obermeier)
Honorable Member Registered
Lifters were not changed to solid until 1934. 8 cyl cams are the same for all '30-'33 H 8's, but in '34 they changed to gear drive, so cam rotated in opposite way. Lifters (roller type) are the same for Essex 6 and Terraplane 6 & 8, and H8 until 1933.
Posted : 31/10/2022 9:31 am
