Source for Pistons
Source for Pistons
5 Users
(@Bill Kile)
The Railton Owners Club is looking for a source for a set of pistons for the Hudson 8 cylinder engines. Can anyone recommend a supplier?
Posted : 09/02/2019 2:52 am
(@dlm31)
Noble Member Registered
I know Dale Cooper @ Ace Auto Parts can help with these.
Posted : 12/02/2019 2:55 am
(@Bill Kile)
Thank you very much. I will pass Dale's contact information on to the Railton organization.
Posted : 12/02/2019 6:12 am
(@obermeier)
Honorable Member Registered
Another source for U.K. people - Austin Maxi 1500 pistons are an exact match.
Posted : 13/02/2019 12:52 pm
 BoJo
(@bojo)
Clark, that is very interesting. It would be interesting hear from you how you learned the Maxi 1500 pistons matched perfectly with the Railton's piston. Has anyone used then in a Railton engine?
Posted : 13/02/2019 8:07 pm
(@obermeier)
Had a friend . now deceased., worked for a engine rebuilder. He had a Jet, and discovered the match. Jet pistons are exactly same as earlier 3" models, except 2 oz. lighter, and no split skirt. I don't know if anyone has used them in a Railton, which is after all just a Hudson engine! Only Maxi 1500 will do. 1750 are bigger.
Geoff
Posted : 13/02/2019 8:54 pm
(@Larry Hudson)
I have been following this thread with interest. From this I gather the Jet piston and the 8 pistons are the same. I know the Jet engine is a redo of the 8 with some improvements. I will be hunting some pistons for my Jet soon. Thanks for the info. LHud
Posted : 13/02/2019 11:38 pm
(@obermeier)
Dale Cooper has 3" pistons which will fit all models, including Step-down 8 and Jet. The Jet motor was I n fact a completely new motor, but they must have used the same boring equipment for the cylinders. Other than the pistons, there is no relationship to the former 8.
Posted : 14/02/2019 8:26 am
