Here's a few pictures of what I'm looking for to get the engine restored. New pistons, rods, rings, valve timing chain and gears (ok, that's about all the internals!). Need a generator, and updraft marvel carburetor, will want a Startix unit eventually. Most of the rest is there. The pans are dirty but mostly look ok. Somebody punched some larger holes in the metal screen on the bottom pan, so I may have to see about fixing that. Not sure why they did that, except they intended to enhance oil flow. Also need the vacuum fuel pump tank that mounts on the firewall (you can see bolts for it on firewall and you can see fuel lines that go to the missing pump). The fuel lines are copper and I intend to replace those.
I mounted one of the Stabilite headlamps, but the ones I have broken or missing lenses. the cowl lamps seem fine. Will also want to find a Startix unit for this car.
