Ed, that was one of the Delco Remy part numbers. RBM had another number for the same part. They were interchangeable.
Posted : 14/03/2015 10:21 am
I'm unsure of what solenoid I will need now that I am converting to 12 volt. Could someone tell me the number?
Posted : 10/04/2015 8:15 am
anyone?
Posted : 13/07/2015 7:30 am
Ideally a '48-'49 solenoid, since the pull-in and hold-in coils are separate, each with it's own terminal. Let's you put a resistor in the hold-in coil circuit, which is energized whenever you're above cut-in speed.
For the pull-in coil there's not much of a problem, as it's energized so briefly . . . I suggest powering it with a 16 ga. wire, which will act as somewhat of a resistor.
Posted : 13/07/2015 1:15 pm
Page 2 / 2
Prev
