overdrive solenoid
overdrive solenoid
8 Users
(@dlydon7fav)
I have an overdrive solenoid #1118132. Does anyone know what it fits? It is the same length and same pawl length as #118147. Are the interchangeable?
Thanks'
Videoman
Posted : 15/02/2014 5:35 am
(@tallent-r)
Noble Member Registered
Moved to "Hudson" sub-forum (from "Club & Forum Suggestions and Comments")
Posted : 15/02/2014 5:51 am
(@Lance Walker)
[quote="John Fromm" post=4124]I have an overdrive solenoid #1118132. Does anyone know what it fits? It is the same length and same pawl length as #118147. Are the interchangeable?
Thanks'
Videoman John, The info I have indicates that 1118132 is a 12volt model while 1118147 is a 6 volt model. Also, 1118147 was superceeded by 1118164 which was indeed used on the 52-3 Hudsons on their overdrive setup. Hope this helps.
Posted : 15/02/2014 6:19 am
(@dlydon7fav)
Lance,
Thanks for the info.
Posted : 15/02/2014 10:53 am
(@dlydon7fav)
Would a 12v overdrive solenoid work on a 6v system?
Posted : 15/02/2014 11:07 am
(@kholmes)
No,but it's good sales material! Lots of folks converting to 12v and looking for 12v solenoids.
Posted : 15/02/2014 12:54 pm
(@ec36616)
Active Member Registered
1118132 is a 12 volt for Studebaker. 1118147 is a 6 volt for Hudson double lever overdrive.
Posted : 15/02/2014 2:04 pm
(@Lance Walker)
John, Let me know if you need a 6 volt model. I've got quite a number of them.
Posted : 16/02/2014 12:12 am
(@hoffmanbike)
Eminent Member Registered
Lance
Do you have info.on #1118134 as I can't find it's application.
Posted : 16/02/2014 1:28 am
(@Lance Walker)
[quote="Paul Batson" post=4156]Lance
Do you have info.on #1118134 as I can't find it's application. This solenoid was used origionally on the 1950 Hudson with overdrive. It was superceeded by the 1118147 which was again superceeded by 1118164. Gets a little complicated Paul. 🙂 There may have been some units that went out with this part in 1951 as well. It was for a Warner R-10 overdrive.
Posted : 16/02/2014 1:49 am
(@dlydon7fav)
Lance,
Thanks for the offer,but I have three of them I am trying to get rid of.
Thanks,
John
Posted : 17/02/2014 11:12 am
(@Frank Riley)
John,
I have a 6volt version and am looking to convert to 12volt.....
Rileystudio@hotmail.com
Posted : 10/03/2015 5:59 am
(@xrw-urabus)
Estimable Member Registered
[quote="John Fromm" post=4171]Lance,
Thanks,
JohnWhich version do you have that you are hoping to sell? I would be interested if it the right version and reasonable price. Always good to have a spare.
Posted : 13/03/2015 12:40 pm
(@Lance Walker)
I have a bunch. What number are you looking for so I can check and see.
Posted : 14/03/2015 12:13 am
(@xrw-urabus)
#1118134 solenoid was used origionally on the 1950 Hudson with overdrive
Posted : 14/03/2015 9:28 am
Page 1 / 2
