Circuit breaker que...
Circuit breaker question: 1953 Hornet Hydramatic.
4 Users
(@pa462)
Estimable Member Registered
I recently had a wiring fault causing a short in the feed to the starter solenoid. This fault caused all electrics to temporarily die and then return after a few minutes. I have replaced a damaged piece of wire and this seems to have fixed the fault. I assume that there is a circuit breaker somewhere. Can anyone please tell me where the circuit breaker is located and what it looks like.
Many thanks,
Brian.
Posted : 17/01/2014 6:52 am
(@hudtruck)
Trusted Member Registered
Actually there are 2. One(25amp) is in the headlight switch for them and the other aux CB(20 amp) is above the steering column on a support rail behind the gauge cluster.
Posted : 17/01/2014 1:23 pm
(@pa462)
Thank you Ron.
Regards,
Brian.
Posted : 17/01/2014 8:13 pm
(@kholmes)
These are "auto-reset" breakers, not the kind you have to reset manually after they trip.
Posted : 18/01/2014 1:16 am
(@35terraplane)
Prominent Member Registered
Those headlight switch breakers have a nasty habit of tripping - when you're on a winding road doing about 60!!! LOL
Alex Burr
Posted : 18/01/2014 6:31 am
