This has carb to carb linkage and a line to provide distributor vacuum from both carbs as well as to Carter WDO carbs with choke assemblies removed for improved flow. No cracks or damage to manifold. Would polish easily. Asking $650. Let me know before it goes on EBAY. More pictures available, if you like.
Posted : 24/10/2013 5:53 pm
Are the carbs appropriate for a 262, or only a 308?
Posted : 07/11/2013 5:39 am
I have never run this carb set-up. It is as I bought it. I do believe the carbs are a little smaller than the Carter WGDs that I run on a much modified 308. Certainly they need to be rebuilt before use. Hope that helps. Going to EBAY in a day or two.
Posted : 07/11/2013 6:02 am
