Has anyone had success in overheating? Saw TV show that touted Evans Waterless Coolant?
Read reviews, some good, some bad. Anyone experience a solution?
Posted : 09/10/2013 7:59 pm
Moved to "Hudson" forum (was posted in "Club & Forum suggestions & comments" section)
Posted : 10/10/2013 4:24 am
You should not need any additive to help your Hudson run cool if everything in your cooling System is in order.
Those Additives may be useful to lower Temps a few degrees for Racing or pulling heavy Loads....
Posted : 10/10/2013 5:00 pm
I'd call such additives "compensating for the problem instead of fixing it." As said, if the cooling system's in good condition, it should not overheat
Posted : 13/10/2013 7:31 am
