Hudson
2
Posts
2
Users
Reactions
32
Views
RE: 35 Terraplane oil pan gaskets. I purchased a gasket set from Olson. It included an O-ring with dipper tray/oil pan gaskets. Is the oil ring used on the 35 oil pans? I don't recall there being one on the pickup tube when I removed it.
Posted : 19/07/2025 4:34 am
yes it should have one. Also make sure you don't use too much sealant around the rear sump feed hole in the block
Posted : 23/07/2025 7:56 am
