Stainless side trim...
Stainless side trim removal
2 Users
(@Bill Johnson)
I need advice how to remove stainless side trim from a 1952 Wasp. The Body Service Manual states to use "wedge-shape fiber tool" to pry up the front edge of the moulding. This sounds like the moulding could be easily bent. Is the moulding held in place with spring clips like some other make cars ?
Can someone recommend a source for the fiber tool ? The trim has a small dent that could be easily repaired if off the car but I do not want to add more damage by not knowing the proper way to remove it.
Any advice or suggestions would be appreciated.
Thank you,
Bill
Posted : 03/08/2023 4:12 pm
(@Terry Layman)
Bill, I found a variety of fiber pry tools at Harbor Freight. They flex a little, but are quite strong. You might wish to file the edge for easier sliding under the trim. Another, yet wider, fiber blade used for drywall refinishing could be a good choice too. I would slightly "round off" the corners of any blade to help eliminate any chance of marring of the cars finish.
Hope this helps. Terry
Posted : 03/08/2023 4:51 pm
(@Bill Johnson)
I will check Harbor Freight in the AM. Do you know if the trim just pops off with using the tools or is there some secret ?
Thank you,
Posted : 03/08/2023 5:16 pm
(@Terry Layman)
I do not know for certain. I have a reprint of the Hudson Body Service Manual, but can't discern the procedure well enough to give guidance. Perhaps body shop and/or paint specialists might come to your rescue. I'll look to see if online videos exist. Terry
Posted : 04/08/2023 1:31 am
(@Terry Layman)
Under the Search heading, type Hornet stainless removal. It looks helpful and has good advice as well. Also I just discovered a video, via Google, called Sam's Garage "Hudson Hornet Project." I'll watch it too.
Posted : 04/08/2023 2:28 am
(@Terry Layman)
More precisely "Project Hudson Hornet."
Posted : 04/08/2023 2:41 am
(@Bill Johnson)
Terry,
If you are still interested in the trim removal, I received a tip from a person who has removed the trim with a Red Devil paint scraper. The scraper blade will slip under the trim. The back side of the scraper holding the blade is rounded and acts as a fulcrum when the handle is pushed down lifting the trim. Seems to work very well without using screwdrivers and other pry bar tools.
Bill
Posted : 10/08/2023 5:19 am
(@Terry Layman)
Bill,
I appreciate you lending this tip and your experienced
craftmanship. I was responding to an earlier question and lending my best advice. Hopefully, he'll get his repair done flawlessly.
Terry
Posted : 10/08/2023 5:34 am
