Need help to identify an Autolite Distributor IR 4001 4G. I think it must be for some early Hudson since with other Hudson parts. Does anyone know if this fits a Hudson and what model or year ? Picture attached/
Thank you,
Bill
Posted : 25/07/2023 5:32 am
It looks late 1920s but that number doesn't tie in with the Hudson and Essex distributor numbers I have.
Posted : 26/07/2023 11:34 pm
If Interested, received reply from AAA member. The dist, number is IB 4000. The "B" is off-stamped and looks like a "R". The correct number should be IBA 4000. It replaced the American Bosch dist. mid 1926 Essex and then used on the 1927.
Thank you
Posted : 27/07/2023 2:40 am
That is correct. The 1928 Essex used the same distributor, except it had an electrolock cable in place of the terminal on the side.
Posted : 27/07/2023 10:25 am
