1946 Hudson Truck R...
1946 Hudson Truck Rear end
2 Users
(@Kevin Morrow)
I was looking at some old threads from the HET Forum, and there was talk that a Ford 8.8 rear end from early Ford Explorers are a good alternative to the old Ford 9" rears or old Chrysler 8 3/4 rears. These 8.8 rears are 60" wide and come with 3,73 gear ratio with same lug nut pattern as Hudson. Any comments would be appreciated. Thank you, Kevin Morrow
Posted : 28/03/2023 7:44 am
(@Dany Spring)
60" is the same as the factory rear, so that is a good fit. You will like the 3.73 ratio. If the Explorer application is coil springs, There will be a bunch of bracketry to cut off. Not a big deal, but time consuming. As far as strength, the 8.8 isn't quite as strong as a 9", but it will hold up well for what you have planned for it, and there are a lot of gear ratio choices available if you want to make a change. I'm using one in the 54 I'm building now.
Posted : 28/03/2023 8:11 am
