1942 Hudson, windsi...
1942 Hudson, windsield wiper plastic knob
2 Users
(@Calvin Parsons)
Best way to put a new knob on the control arm thru the dash.  Would the best bet be to use a c clamp?  Can't push it on by hand. Thanks.
Posted : 17/03/2022 10:53 am
(@adamb)
Why don't you ask Gregg Eshelman? I assume you bought the knob from him? The shaft should have fine splines on it. Measure the outer diameter of these splines with a dial caliper. It may be necessary to drill the bore on the back of the knob slightly larger be be able to press it over the shaft splines.
Posted : 17/03/2022 2:27 pm
(@Calvin Parsons)
Thanks, I'll try that.
Posted : 18/03/2022 1:41 pm
