I have searched using multiple query's like tire, psi, pressure, etc, and I couldn't find what I was looking for.
I am about to get the Hornet out on the road first time in 2022 and I realized I did not know what the proper tire pressure is supposed to be set at. Any pointers? I have Coker wide whitewalls, TIA!
Stay Safe!!
Wide white radials, or bias plies? There's a big difference in recommended pressures. Bias are 26psi front, 24 psi rear. Radials need higher pressure, I run mine at 40 Psi front and 38 psi rear, to keep the white side walls intact, as well as reduce the low speed steering effort. Radials require much more steering effort at low speed/ parking maneuvers.
Tubeless Radials, thank you Kenneth, you're always a wealth of information!
