overdrive solenoid
overdrive solenoid
2 Users
(@Terry Irvin)
I picked up a double lever OD transmission and removed and cleaned up the OD solenoid thinking it was 6v but it won't engage using a battery charger as a 6v source but when I switch the charger to 12v the solenoid works fine. The number on the solenoid is 6AR10B-62. Is the battery charger not a good source for testing?  Terry
Posted : 12/08/2021 8:29 am
(@Dany Spring)
Depending on the charger, it may not put out enough amperage to make it function properly.
Posted : 13/08/2021 2:53 am
(@Terry Irvin)
That was the case. I took it over to where my C6 was at and jumped it directly off the 6v  battery and it worked fine. Thanks  Terry
Posted : 13/08/2021 5:46 am
