Oil usage
2 Users
(@biggus13)
Estimable Member Registered
My 48 Super Six uses a little oil but does not smoke at all. My compression is 100 to 108 across the board. I get a pretty good stain on the garage floor after some highway driving and I think its coming from the vent tube. Is this an indicator of worn valve guides? Can I use valve seals from a chevy maybe? Any input would be helpful.
Posted : 30/07/2021 2:52 pm
(@pfeifer)
Prominent Member Registered
4 Common Causes of Blow-by
[list=1]
[*]Worn out pistons
[*]Worn out piston rings
[*]Damaged cylinder walls
[*]Faulty Crankcase ventilation
[/list]
https://www.motorstate.com/blow-by-causes-and-solutions/
https://www.mishimoto.com/engineering/2016/01/blow-by-101-what-is-blow-by/
all motor parts are available thru Hudson vendors.
https://www.hudsonmotorcarco.com/parts.htm
Posted : 31/07/2021 12:11 am
(@pfeifer)
http://mewagner.com/?p=444
Adjustable pcv valve conversion
Posted : 31/07/2021 1:02 am
(@biggus13)
Hi Kerry - these are good articles. I once had a 50 Ford P/U with a 289 in it. It smoked a lot so I ran a piece of flexible electrical conduit from the breather into the snorkel of the air cleaner! Worked great on a worn out motor! I guess the real issue here is that I should be looking for an internal problem. I had the motor apart 5000 miles ago. Got a sleeve put in a cylinder. Otherwise all stock 262. It's clean inside. As I said the compression is pretty good but I guess there is a possibility of cracked rings or something. I get just a smidge of pre-ignition at high speed acceleration, that I can't quite get out. I guess for now, the catch can system would be good to use.
You've got me thinking now.....
Thanks for your helpful suggestions!
Posted : 31/07/2021 4:05 am
