1934 Terraplane mot...
1934 Terraplane motor options
2 Users
(@lonbaker)
Active Member Registered
Will a later model 202 bolt up to a stock 34 3 speed transmission? I’ve got a couple 202’s that I might install to get it back running around again. Original motor got hot & multiple cylinders cracked.
Posted : 27/07/2021 1:37 pm
(@obermeier)
Honorable Member Registered
Short answer - No.   Long answer - the transmission, clutch, starter, shift levers, pedal mounts,  are all different.  the only way to use a Jet  motor would be to use the entire unit, and that would also entail a bit of engineering around the gearshift and throwout  mechanisms.
Posted : 27/07/2021 4:47 pm
