fuel and temp gauge...
fuel and temp gauge work only sometimes.
2 Users
(@jcurcio)
Active Member Registered
The fuel and temp gauges in the Jet only register once in a while, they show as if ignition off but will read correctly now and again.when driving. The last bug in the Jet I haven't figured out! Thanks!
Posted : 20/05/2021 6:27 am
(@obermeier)
Honorable Member Registered
Most likely the 5v regulator is dodgy, or has loose contacts, Sits on the back ( or technically the front) of the instrument panel. It could either be the mounting screw loose, or the voltage supply screw, or the output terminal screw.
Posted : 20/05/2021 10:18 am
(@jcurcio)
Thank you so much Geoff.
Posted : 20/05/2021 11:34 am
