6V to 12V overdrive...
6V to 12V overdrive conversion
2 Users
(@biggus13)
Estimable Member Registered
I need to change my 1950 6V BW overdrive to run on 12V. New parts are pretty pricy and seem to be more cheaply made, so i am considering used parts. Can anyone tell me how to tell a 6V solenoid from a 12V? Or a 6V relay from a 12V?
Posted : 20/04/2021 4:15 am
(@dafast)
Honorable Member Registered
The solenoids look the same 6v and 12v. There is a short throw and longer throw. You can check the length of the throw with a jumper wire and battery. When I converted mine from 6v to 12v I was going to use a 12v from a mid 60’’s GM but the throw was wrong. I used a solenoid from a 60’s ford that matched up and works fine. I don’t have a relay in it. I use a single wire with a toggle switch.
Posted : 20/04/2021 7:51 am
(@biggus13)
Thanks Ed. I have heard of people using a switch. I might go that route. It's getting hard to find some of this stuff - cars from the 60's are getting scarcer and they didn't all have overdrive!
Posted : 21/04/2021 5:02 am
