losing water
4 Users
(@kitterman)
Estimable Member Registered
My hornet loses about a gallon of coolant every 50 miles.  I don't see any obvious leaks.  The radiator has been recored.  Any suggestion about how to find where it is going and how to fix it would be welcome
Posted : 10/04/2021 12:52 am
(@pfeifer)
Prominent Member Registered
Check the tailpipe when motor is running for water droplets coming out, a sign of a blown headgasket.
Check the oil for moisture/condensation, light brown foamy oil.
How hot is it running?
Posted : 10/04/2021 4:53 am
(@adamb)
There is a 1" concave freeze plug at the top rear of the block that is inaccessible with the engine in the car, as it is by the firewall. These often do spring a leak after corroding. Look for a drip at the rear of the engine when parked with engine running and fully warmed up.
Posted : 08/05/2021 10:43 am
(@josh-1938)
If parking on a cement drive should see a wet spot when loosing a gallon, however, if parking on gravel slide something underneath to help pin point location of a drip. Another possibility if you regularly refill fill to just below cap it may throw out some water to get a lower level in tank for expansion. If suspect leaking into p[an let set overnight then jack (and block up) car enough to slide underneath then use a clear plastic Jar to drain a little oil from pan..([u]Do this over a regular Drain pan[/u]) If water/antifreeze in pan it usually drains out first then re-install the drain plug. If water/antifreeze didnt appear at first let the Jar set overnight to see if water separates from oil.
Posted : 09/05/2021 5:00 pm
