distributor cap for...
distributor cap for '51 Hornet
3 Users
(@hotrodwench)
Active Member Registered
A friend of mine has offered me a distributor cap which he thinks will fit my '51 Hornet engine. It's an AL-132. Does anyone know if this is the correct replacement cap? Thanks.
Posted : 11/01/2021 7:14 am
(@Christopher Chancellor)
If your 1951 car has the original Auto-Lite IAT-4009B distributor, an AL-106 cap will fit. The AL-132 will likely not.
The AL-106 is common:
https://brillman.com/product/6-cylinder-prestolite-iat-distributor-cap/
https://www.napaonline.com/en/p/ECHAL106?vehicleAddPDP=true
If your car is using another model of distributor than a IAT-4009 series, then maybe.
Posted : 12/01/2021 4:13 pm
 ok54
(@ok54)
[b][size=4]Different manufacturers use different part numbers. Who makes the cap he's offering you?[/size][/b]
Posted : 13/01/2021 1:57 am
(@hotrodwench)
Thanks for the replies. There is no indication of the manufacturers as far as I can see, but on the inside it says IAT-1003. I guess with caps like this if it fits, it works, if not it doesn't. Or is it more complicated?
Posted : 13/01/2021 3:41 am
 ok54
(@ok54)
[b][b][sub][size=4][/size][/sub][/b][/b][size=4]IAT 1003 is an original Autolite cap for a 1950 Pacemaker, AL 132 is the Standard (SMP) part number.[/size]
Posted : 13/01/2021 9:06 am
(@hotrodwench)
Thanks to all for your input.
Posted : 13/01/2021 11:47 pm
