I would like to update the brake system on my Hornet. The bendix treadle vac is outdated an not trustworthy . Has anyone installed a new style brake booster with master cylinder on they re 54 Hornet An if so what parts did you use?
David, you've posted this under "Club and Forum -- suggestions and comments". This is where people poste ideas about our website or suggestions about our club. I don't think you're going to find many responses to your question here. May I suggest that you re-post to the "Hudson" section, at this forum?
DAVID
I'M NOT SURE WHY YOUR CALLING THE TREDALE VAC OUT DATED AND UNTRUST WORTHY YES IT WAS REPLACED BY GM IN THE LATE 59 BUT I'VE HAD GOOD LUCK WITH THE ONES IN MY CARS THE ONE IN MY 57 HOLLYWOOD HAS BEEN IN THE CAR AND WORKING JUST FINE FOR OVER 25 YEARS AFTER IT WAS REBUILT I'VE OWNED THE CAR FOR OVER 45 YEARS AND HAVE ONLY REBUILT IT 2 TIMES 9 IT MUST BE DONE CORRECTLY WITH OUT CUTTING CORNERS I DOUGHT YOU COULD GET THAT SERVICE FROM ANY OTHER UNIT POWER OR NON POWER YES THEY ARE NOT CHEAP TO REBUILD BUT IT DONE RIGHT THEY WORK JUST FINE I'VE OWNED OVER 15 15 55,56,57'S OVER THE YEARS AND HAVE DRIVEN THEM OVER 50,000 MILES WITH HAVING ONE FAIL.
HUDSONLY
PAULARGETYPE
IF YOU NEED HELP WITH THE REBUILD LET ME KNOW I KNOW I CAN HELP
HETHUDSON1957@AOL.COM DROP THE HET
David,
Please explain to me the not trustworthy part, I may be able to help.
John Forkner
If a part has lasted over 50 years and is now Un-Trustworthy because it is worn out . Why not rebuild it and get another 50 + years of service out of it.
If you buy an item from some HotRod shop to "Update it" that they imported from Mexico. Is it going to last 50 years? Sure it will.......
Roger
