53 Hornet freeze pl...
53 Hornet freeze plugs
3 Users
(@Tom Brintnall)
As I was finishing up a re-build of a 53 Hornet engine I found the rear freeze plug was over sized compared to the other 2. First 2 were 2" dia, the 3rd was 2 1/8" dia. Has anyone seen this before? I have done several Big 6 engines and this is a first for me.
Tom
Posted : 23/03/2020 1:43 am
(@pfeifer)
Prominent Member Registered
If you are talking about the actual hole in the block, no haven't seen it. Bet someone replaced it before and reamed out the hole.
Posted : 23/03/2020 1:55 am
(@Tom Brintnall)
Yes, the third hole in the block is oversized to 2 1/8". Actually had to trim the OD of the 2 1/8 freeze plug about .035" to get it to go in. Did it on a small lathe, very carefully and had a good interference fit.
Posted : 23/03/2020 2:45 am
(@adamb)
You could have saved yourself the trouble of turning the 2-1/8" cup on the lathe by using a 2-3/32" cup, Dorman part # 555-049. https://www.dormanproducts.com/p-7345-555-049.aspx
Posted : 23/03/2020 7:14 am
(@Tom Brintnall)
It's what I had, so I made it work. Parts stores around here don't stock them any more, had to get it from a machine shop...
Posted : 24/03/2020 7:00 am
(@adamb)
I buy almost everything online these days, less hassle and running around to stores, as well as usually being cheaper, even with shipping, if free shipping isn't offered.
Posted : 24/03/2020 8:46 am
