need drawing of overdrive for a 49 Hudson
Here you go.
The person working on my overdrive liked the pictures. He was wondering about the color of the wires coming out of the solenoid.
Would you have any info on that? Thanks so much for your help
Charles, I'm not sure what your question is. Can you re-phrase or amplify?
And by the way, unless you want the wiring to be absolutely as original, I recommend you consider getting a '50 or later solenoid and relay. The wiring is much simpler, and it does away with the overly complicated '49 relay.
Note: you can use a '49 solenoid with the '50 and later wiring. Just mimic the later solenoid by connecting the #3 and the #4 terminals together.
[quote="Charles Bogaard" post=25693]The person working on my overdrive liked the pictures. He was wondering about the color of the wires coming out of the solenoid.
The colors are marked on the diagram.
