Is there a source for glove box springs ?
I believe someone's making the 1936 springs (see the Hudson Repro Parts page, dashboard section, [url= http://www.detailedconcepts.net/Repro_Table.pdf ]http://www.detailedconcepts.net/Repro_Table.pdf[/url] ) -- there's a photo you can compare your spring to.
I would suggest that you publish a photo of your spring (if you have one left), because a lot of people have piles of Hudson stuff but wouldn't know a '35 glove box spring even if they had it.
Jon,
Will try to get the '36 springs and see if they work. I don't have any springs at all.
Thanks
You've probably thought of this already, but: have you checked the National roster to see if any '35 owners live in your area? That way you could drive over and look at the correct springs yourself. Or, e-mail them with a photo of the 1936 springs (there is a photo on the Hudson Repro webpage) and ask if they could please compare it to their own glove box springs.
Jon,
Thanks so much for posting the repro site. I see the springs plus another item I have been searching for. If the person still makes those '36 springs, I am sure I cam make them work.
Thanks again
You're welcome! Glad the site was of some use to you.
