Twin Supercharged
Twin Supercharged
1 Users
(@hudbob)
Estimable Member Registered
I am posting this for Fred Haller AKA "TwinSupercharged" on the forum, Paul Butler is trying to sort out some details for him.
Here's what's going on with Fred.
I installed a Frank Hughes oil pump/filter on my 308 Hudson. It is leaking oil at what appears to be the seam where the top cap is held on with socket head cap screws. All cap screws are very tight and all hose connections are not leaking. There is a hex bolt with a wire lock that Frank installed. It also is leaking. I am looking to see if there are other units out there that are leaking and what was the cause and the fix-it. I have Clifford tube headers and it is very difficult to see the pump or to do any maintenance on the pump without removing both the headers and the intake manifold. Any info you can share would be appreciated. Thanks, Fred Haller, xxxjfhaller@cox.netxxx (delete the xxx's) On the forum as TwinSupercharged.
Posted : 25/08/2019 3:43 pm
