I bought a Ron Francis 12 circuit 6 volt replacement system (WR-54) My second problem was a good location for the fuse block. The typical left hand kickpanel doesn't look too promising. It's really crowded in there. What locations have folks used when rewiring with a fuse system. Thank you.
Dean Prodromos
Posted : 09/08/2019 11:22 am
On some replacement harness the wires are long enough to mount the fuse block on the passenger side kick panel where there is a lot more room to work without the steering column in the way..
Posted : 09/08/2019 12:28 pm
Firewall in front of driver(inside); left of steering column.
Posted : 17/08/2019 8:49 am
