Any Hudson venders sell just the pump? I can get one from Mikes carburetor, but thought I'd check the club guys. ALSO, what is the difference between a 968s and a 2113s carb. I pulled the carbs off the Hornet, took the float bowl cover off and the pump leather fell apart. I have a spare carb so I took the float bowl cover off it and am using that pump till I can get a new one...or two. The metering rod in the carb on the car is 75961 which is standard, one step lean according to previous posts. The metering rod in the spare carb is 75955, standard on the 2113s. Are metering rods the only difference? Terry
No problem Terry. Call me 704 792 911zero
I'm fishing Lance, I'll call you Monday...I also need a knob for the fog lights I installed.....the one with the set screw for the flat spot shaft and the prettiest one you have! Terry
No problem Terry. Let me know what you need. L.
Accelerator pump....perfect fit, chrome dash knob....great condition, perfect fit, thanks Lance!
My pleasure sir.
