Help installing wea...
Help installing weather master
1 Users
(@jethro)
Estimable Member Registered
I need advice on how to install the weather master in my 39 92 sedan. It came from a 39 CC sedan. So it is for 39 cars. I just don't know how it is mounted. Please help
Posted : 07/11/2018 1:17 pm
(@jethro)
Just wanted to bring this back up front. STILL needing some sort of advice as to how the weather master for 1939 is installed. I did manage to fit it up under the cowl vent and discovered that the cowl vent rod has to go thru the weather master. But I have no clue as to how it mounts up there. Maybe I am missing pieces, not sure. Here are a couple pictures of the weather master
Posted : 20/01/2019 4:57 am
(@jethro)
Well I must thank Ivan (in Canada) for his help in adding me with direction of install of the weather master. He sent me pictures of the fire wall of the car weather master comes from. And it shows two holes drilled where it mounted. Now I don't know if there were brackets there but it is a big help.
Thank you Ivan
Posted : 09/02/2019 1:06 pm
