intake manifold nee...
intake manifold needed
2 Users
(@Larry Bowerman)
I need an intake manifold for a twin H 262. Mine has a hole. Spacing of studs for carb is 2-11/16 inch.
Respond here or call me at (734) 502-6945. You may have to leave a message because I tend not to answer calls that I don't recognize the number. Thanks.
Larry Bowwerman
Posted : 21/08/2018 8:23 am
(@josh-1938)
Is the hole just a soft plug eroded or rusted out underneath? I never discard a Twin H and patch if possible.
Posted : 21/08/2018 4:42 pm
(@Larry Bowerman)
The hole is a rust hole on the underside. Its about the size of the tip of my finger. I'm concerned that the location of the hole will make it difficult to repair. I would rather have a good manifold if I can find one.
Posted : 22/08/2018 3:07 am
(@josh-1938)
[b]Understand. 262 Intakes are scarce but someone may have one but don't discard yours.[/b] There are ways to patch that work well. I patched a real bad one then put a thin stainless plate between manifolds to block off the exhaust just in case didn't hold years ago. Only drawback was cold start ran rough a few minutes without exh heat..
Posted : 22/08/2018 4:07 am
