Emergency brake han...
Emergency brake handle for 46 pickup
3 Users
(@Gerald Dye)
I am in need of an emergency brake handle assembly for a 1946 pickup. A previous owner removed the complete handle. Ii still has the support piece that goes from the dash to the firewall. Does anybody have an idea where I might find one?
Posted : 19/06/2018 4:02 am
(@jstreich49)
Estimable Member Registered
Any Hudson, 1941-1947 is the same. Somebody must have one somewhere.
Posted : 19/06/2018 10:37 am
(@Gerald Dye)
I will try some of the folks in Colorado first.
Posted : 19/06/2018 1:40 pm
(@Lance Walker)
Do you need just the handle or handle and cable assembly?
Posted : 20/06/2018 1:19 am
(@Gerald Dye)
All I need is the handle assembly that includes the rod to where it would connect to the cable.
Posted : 20/06/2018 10:14 am
(@Lance Walker)
OK no problem. I have one I'll sell you. 704 792 911zero.
Posted : 20/06/2018 11:41 am
(@Gerald Dye)
Thank you. I will give you a call tomorrow (Saturday) afternoon. I am not sure how it mounts to the bracket under the dash, but I am sure I can figure it out. I hope your's includes the ratchet rod.
Gerry Dye 720.454.6807
Posted : 22/06/2018 11:52 am
(@Gerald Dye)
Lance,
Thank you for the quick delivery of the E-brake assembly. It is in perfect condition and bolts right onto the existing bracket. Little clean up and I will be good to go. There are a couple of companies in Denver that can make a new cable. Thanks again for the great service.
Posted : 08/07/2018 8:33 am
