6 volt halogen head...
6 volt halogen headlight bulbs
8 Users
(@Bill Johnson)
Read old forum about using 6 volt halogen headlight bulbs. Is there a custom plug socket or diagram how to use these in a 1935 ? Seems the old 6 volt bulbs are more expensive and less bright ?? Any tips would be appreciated.
Posted : 26/04/2018 4:37 pm
(@dafast)
Honorable Member Registered
My cousin put 6 volt Halogens in his 1929 Peerless and the difference was like night and day. I think they just went right in without any changes to the sockets.
Posted : 27/04/2018 12:26 am
(@Ryan LeCompte)
Any idea where to get them? I'd like to look into it for my Franklin. My Hudson already had a 12v conversion.
Posted : 27/04/2018 6:41 am
(@dafast)
I took a photo of the add and will attempt to attach it.
Posted : 27/04/2018 7:48 am
(@josh-1938)
[b]FYI
I got my '37 Halogen Bulbs from Little British Car Co in Mi. www.little british car co.com or email lbcarco@lbcar.co.com[/b][b] 800 637 9640. They have 6 & 12V and small replacement bulbs to fit orig sockets.....[/b][/b]
Posted : 28/04/2018 5:13 pm
(@Bill Johnson)
Thank You for the reply. I received e-mail from Australia for U.S. supplier www.classicbulbs.com which is the Little British Car web site too. I was given part number # 170-756H Pre-Focus halogen bulbs for $ 29.00 each. Not cheap but if gives good light then good. Thanks to all who are willing to help a new owner to an old car I know very little about.
Best regards,
Bill
Posted : 29/04/2018 2:11 am
(@obermeier)
Don't be too surprised if there is not as much brilliance as you expected. Unless you fit a relay, there may not be much improvement.
Posted : 29/04/2018 10:47 am
(@josh-1938)
Geoff makes a good point about Relays. I forgot to mention when I posted the Company to purchase Bulbs. I have Relays on mine to get full Battery Voltage. You need a Relay on both High and Low Beam. Relays can be purchased from any Auto Store. Diagram to wire the Headlight Relays can be obtained Online by goggle [u][i]dual headlight wiring kit[/i][/u] Additionally, Ive seen nice ready made dual relay Kits around $40 Online thats practically Plug In saving a lot of time & trouble. They come with wiring pretty much done done, Relays & fuse...Moss Motors/Ebay/ Amazon, etc... Maybe Little British have the Kit too....
Posted : 29/04/2018 1:02 pm
(@tallent-r)
Noble Member Registered
...and to add to the suggestions (of using the halogen bulbs, and relays): solder a ground wire to your headlight socket, and run the wire down to the nearest connection to the car's frame. Also, get your reflectors re-plated (either with original silver plating, or with the Uvira aluminum deposit process.
Posted : 29/04/2018 2:28 pm
(@radio-dave)
Doesn't Jim Spencer (HET Club member) sell a prewired suitable relay?
Posted : 22/06/2018 4:38 pm
(@vdshowell)
Eminent Member Registered
Ebay has NOS, dual relay, headlight kits. They come with instructions. The kit I used looked like an old voltage regulator. Apparently dim 6 volt headlights were a problem back in the day.
Posted : 27/06/2018 12:56 pm
