hudson cork clutch
hudson cork clutch
5 Users
(@charles j gugino)
Hello does any one know the thickness of the Hudson clutch cork new thanks.
Posted : 15/12/2017 4:49 am
(@tallent-r)
Noble Member Registered
I'm not sure it makes a difference, but you might want to say what year of Hudson you have. Possibly the 1948 corks have a different thickness than the 1915 corks....
Posted : 15/12/2017 2:54 pm
(@adamb)
Oh Yes, the thickness DOES make a difference. Nominal thickness was around 3/16" (0.187") with a maximum around 0.210" and a minimum around 0.150". If thicker than 0210" , some folks would add another gasket between flywheel and pressure plate in order to get full disengagement of the clutch.
Posted : 16/12/2017 8:47 am
(@adamb)
I assume you need this clutch for your 1952 Hudson Wasp? Model 5B as listed in the roster? Strangely it is listed as a 1952 Super Six 5B, but 5B is the 1952 Wasp. The Super Six model name was abandoned starting the 1952 model year.
Posted : 16/12/2017 8:57 am
(@obermeier)
Honorable Member Registered
The early multi-plate clutches up to 1926 had only 1/32" thickness protruding each side of the plate. From 1927 onwards (single plate) all models had 1/16" thickness each side.
Posted : 16/12/2017 3:35 pm
(@Charles J Gugino)
Thanks for the feedback i recorked my own clutch in a 1950 Pacemaker corkes were totaly wiped out i just took a guess at the thickness and ended at about less than 1/8 and used a disc grinder down to fit the cover needed longer bolts to draw it down .I worried that the clutch would not release but it worked.
Posted : 17/12/2017 10:52 am
(@dlm31)
Charles, are you talking the disc total thickness is .125 ?. That is the thickness of the steel with no corks?. Since you re-corked the disc yourself, did you rebuild the pressure plate too?. Did you check the installed height of the 3 fingers in the pressure plate when it was assembled?. Most all these procedures are in the Hudson Mechanical book. I hope it last. Have you gone out and actually driven the car?. I would think at that thickness, the clutch would/should be slipping. What size of corks did you install?.
Posted : 19/12/2017 3:27 pm
(@Charles J Gugino)
Hi Doug, i used 9/16 to 3/4 tapered corks alternate side to side hot water to soften them i hadto adjust the thickness of the cork to fit the clutch cover on .I used a disc grinder put the disc in my lathe and sanded them down. I had to use longer bolts to start cover on then the regular bolts worked i was concerned that the disc would not release but it works. i drove around my farm area seemed to work ok. this is just temporary so i can move the car in and out of my shop to do body work. it's going to get a power train update Ford 351w AOD trans .
Posted : 21/12/2017 5:04 am
