Heating Problem for...
Heating Problem for my 1952 Twin H Hornet
4 Users
(@Ken Smith)
I just want to thank all my 'hud' bros for their helpful advice with respect to the heating problems that I was experiencing. It turns out that the best advice that I got (which I started with), was to use an infrared gun to shoot the various parts of my cooling system, namely: the rad, the top tank, the thermostat housing, the exit and entrance hoses, etc. Guess what I found? When my gauge started to climb and reached 3/4's, a complete sweep of the cooling components strangely revealed that the engine was NOT over heating! However, aiming the gun at the sending unit proved the unit itself to be defective! In any event, I once again chose to thoroughly flush out the Hornet's cooling system, and this time also added a bottle of 'Water Wetter' to the 50/50 water-antifreeze mix. I learned of this product from another collector car friend, and it apparently helps reduce cooling temps by a further 8-12 *F. So with a new sending unit and some water wetter, my Hornet is back on track, even in +85 F weather temperatures. Again, thanks to all you guys for your helpful advice. Happy Trails to all, from a Canuck! ken
Posted : 07/08/2017 8:13 am
(@tallent-r)
Noble Member Registered
Discussion moved to "Hudson" forum category
Posted : 07/08/2017 3:00 pm
(@Dean Prodromos)
Great information about the infrared thermometer and water wetter. I'll try both. BTW 85+ is a cool morning in Sacramento CA.
Dean
Posted : 18/08/2017 12:29 pm
(@Richard Dryman)
I have used Water Wetter but now use Purple Ice. Works better.
>>>> [url= https://www.youtube.com/watch?v=tAWWqBh36_0&sns=em ]https://www.youtube.com/watch?v=tAWWqBh36_0&sns=em[/url]
Posted : 19/08/2017 1:37 pm
(@Ken Smith)
Thanks for the 'heads up'. Next time around, I too will try Purple Ice. It is amazing what some of these new products can do for our old engines. ken
Posted : 20/08/2017 5:14 pm
(@Ken Smith)
Hi Dean. As you probably saw, one of our members suggests the product 'purple ice' instead of water wetter. I will certainly give it a try next time around. ken
Posted : 20/08/2017 5:16 pm
