Does anyone have the mixing formula or a very close substitute for the dark metalic green, called Pasture green used in 1954?
Bruce
That is an old PPG code 41469
Call your local PPG auto paint store and see if they can locate a modern cross reference color in
the type of paint (enamel, acrylic enamel, urethane single stage, urethane base coat) that you want.
http://paintref.com/cgi-bin/colorcodedisplaym.cgi?year=1954&manuf=Hudson. I like to stick with local suppliers when possible.
also -
Kerry, Thanks for the info. I went to a local shop that does restorations and the painter determined that it pretty well matched Fisher code -3970. I had a spray can mixed and it does blend in very well. I have the formula if anyone would like it.
Bruce
Guys, you have seen my '53 photos. The lower is Palm Beach Green or close to it. NOT the '53 Green.
