Ornament Light Repl...
Ornament Light Replacement
3 Users
(@Callan Braman)
Hey everyone. I've never done this before but how do you get the emblem off the grille on a '51 Hornet? My bulb burned out, I got the bulb, but can't seem to figure out the removal process to change it. The Phillips head screw on top of it can out easy enough, and I can feel two bolts back behind the emblem, and they feel like I'd need a ratchet wrench for 'em. They aren't conveniently located but all the same, is it as simple as sticking a ratchet wrench back up in there and getting those two bolts off?
Posted : 12/05/2017 6:28 pm
 ok54
(@ok54)
You don't remove the ornament, you remove the bulb socket.
Posted : 13/05/2017 12:20 am
(@dennyscars)
Reach up under the ornament. You should be able to feel the wire and the socket. The socket is a normal, spring type that will pop out. Put a new bulb in and pop back in.. That's all there is to it.
Posted : 21/05/2017 2:32 pm
