how do you adjust the rear side window js there a manual that i can down load
Topic moved to "Hudson" forum category
Charlie, which adjustment(s) are you trying to make? tilt in and out or back to front ? Terry
doesnt go all the way up
How close to the top is it? There are two larger phillips screws with washers that hold the channel to the inside of the rear quarters....some play can be made up there. Do you have the channel piece that screws to the roof ? It should be cloth covered and protrudes down about a 1/4 inch from the underside of the roof and the window fits up inside that top piece. My top channel piece was a bare metal flexible piece that I sent to Wildricks and they redid them for me. Terry
Just curious: can you roll it easily up to the point where it stops, or does it begin to give you trouble before that point?
Then, does it stop dead and you can't turn the handle at all, or does it keep going but only with a lot of effort?
Have you taken a flashlight and looked down through the window slot (when window is down) to see if something is jamming the track?
I guess the next step would be to remove the inner upholstery panel and poke around inside the door to find your problem.
