'42 -'47 radiator i...
'42 -'47 radiator info
5 Users
(@Calvin Parsons)
For '42 to '47 Hudson, is the radiator the same for the 8 cylinder and the 6 cylinder ?
Posted : 27/02/2017 2:11 pm
(@Glenn Hebblethwaite)
No. The 8 Cylinder is deeper but otherwise the dame dimensions and inlet/outlet positions.
Posted : 27/02/2017 3:21 pm
(@Calvin Parsons)
Thanks Glenn.
Posted : 27/02/2017 11:03 pm
(@dafast)
Honorable Member Registered
I believe that the cores are the same, but the mounting straps are different. One has mounting bolts under the core, and the other one has mounts outside lower corners. Ed
Posted : 28/02/2017 2:58 am
(@jstreich49)
Estimable Member Registered
Core for the 8 is much thicker with a larger capacity top tank. Correct about mounting differences.
"Ric"
Posted : 28/02/2017 4:11 am
(@Calvin Parsons)
Thanks Ed and Fred.
Posted : 28/02/2017 8:31 am
(@dlm31)
Noble Member Registered
As Ed and Ric have pointed out. The 8 cyl. rad. is different, they both have the same in and out locations, BUT they are different in size, capacity and mounting. The 6 cyl. radiator mounts were the 8 cyl. engine mounts are located. The 8 cyl. rad. has mounts that bolt down on either side with 2 bolts. The holes for the 8 cyl. mounting are there on all chassis, just not used if equipped with the 6 cyl.
Posted : 01/03/2017 3:57 am
(@Calvin Parsons)
Thanks for the added info Doug. I checked on the frame and think I see where they bolt in. I need to talk to you concerning this and a few other questions, and order some parts.
Thanks
Cal
Posted : 01/03/2017 9:41 am
(@dlm31)
Cal, do you have any of these brackets?. I might have some extra's. We use a custom aluminum radiator we have made for these cars. Our radiator is a large core type, looks about the same, but set up for use with the Big 6 engine. the Big 6 has a different location on the top neck and is pressurized. The front splash apron has to be modified to use them, or have the correct 8 cyl.splash apron. We have found those hard to come by, but the 6 cyl.is easily modified.
Something that is substantially different on the '41-'47 cars. VS. the Step-down cars, is the location of the water pump and fan. The earlier engine has an adapter that sits the water pump and fan higher, more in the center of the radiator. Depending on what climate and options on your application, it is recommended to install an electric cooling fan, and turn it on if needed. The built in shroud is also very important to replace. We use a stiff, thin rubber material, around the radiator. This doesn't rattle, and also conforms to the hood when closed. This really helps the air to go thru the rad. instead of around the radiator. It is also very important to use the splash apron, again, it helps direct the air thru the radiator and not go around. Give us a call, thanks doug
Posted : 01/03/2017 10:06 am
(@Calvin Parsons)
Just talked with one of your guys, and sent you an e-mail Thats whats going in, a 308 , figured that 8 cyl info would get me the info I need. Probably should have called you first.
Thanks,Cal
Posted : 01/03/2017 10:20 am
