Door handle disasse...
Door handle disassembly
3 Users
(@kevin222myahoo-com)
Active Member Registered
Can anyone advise on the best method for disassembling a door handle from a 46-7 Super? I need to swap out the base casting with an unbroken (so far...) replacement, but am unsure how to remove the crimped steel 'cup' that is on the handle shaft.
Posted : 18/11/2016 1:21 pm
(@dafast)
Honorable Member Registered
Phil, I also need to replace the base casting on a 46 pickup drivers door . Are the base castings available? Ed Moore
Posted : 20/11/2016 4:46 am
Ed, Lew Bird has no more of them, and all I could get from Doug Wildrick is one with pitted chrome and a broken tab on the front that prevents the handle from over-rotating (I guess I'll drill and tap that spot ant install a threaded stud).
My brother Park had suggested to me that I check with Stu Coleman, in Montana. You might ask him. Let me know if he has an extra complete handle unit, or a better base casting.
I am thinking about asking my contacts in the Manufacturing Engineering labs at Georgia Southern University if they would be willing to 3D scan my old base casting (which I could superglue together) and 3D print a wax model that a foundry could use to make a new casting. I'd just have to find out about costs and whether they could do it in brass rather than pot metal. Then it is a matter of adjusting the 3D file for shrinkage factor, and then chrome plating....
Posted : 20/11/2016 7:52 am
(@dafast)
Thanks for your reply Phil if I find out anything I'll let you know. Ed
Posted : 20/11/2016 11:56 am
(@kholmes)
I'd check with Al Saffrahn too. Contact info on the WTN's list of service providers, Jul-Aug.
Posted : 20/11/2016 12:55 pm
