You will see that the library will disappear for a period of time over the next couple of days.
This is because I am installing a later version of it which takes a little time.
I was hoping to have gotten it done outside of the US day this weekend but encountered a few issues whilst installing it into the test version of the site which has taken me the best part of the last two days off and on to figure out
I will keep the time that the library is unavailable to as short a period as I can however I need to move things about internally on ths site which always takes longer than figured.
Now what will you see from the later version of the library software? No changes at all I hope that are visible! This version is being installed to get around some issues with the older version and to provide some security updates as well.
I try to get as much done as I can outside of the core US day; it helps I'm in the UK of course
New library backend now in & running
I have "exercised" it as much as I can and haven't hit any snags but please message me if you do.
As I said you should see no difference at all; the changes are all underneath the hood 🙂
