Is there a Gasket f...
Is there a Gasket for this?
3 Users
(@Brian)
Here is the photo of the hole in my 37 Hudson's trunk where the fuel neck comes thru. (Gas tank below)
I called Wildrick & was told they didn't make a gasket for this, so is it suppose to have something to fill this hole and go around the fuel filler neck too? If no reproductions, what has been used?
Posted : 07/08/2016 4:27 am
(@stevenh4151)
I don't know about your 37 but I just removed the gas tank from my 36 and it had one piece of one inch foam rubber around the filler neck that also filled the hole in the trunk floor it looked like it had been soaked it some type of tar from the factory to seal it so stuff could not get in your trunk I know that this has not been replaced on my car before because my car was barn find and has only 2000 miles on it.
Posted : 08/08/2016 5:09 am
(@dlm31)
Noble Member Registered
Brian, there is a gasket for this, don't know why someone told you that. They probably mis understood what you needed. This is the tank to body seal
Posted : 11/08/2016 2:17 am
(@Brian)
Thanks Doug, that is really great to hear!
Posted : 11/08/2016 11:07 am
