51 Hornet Dash Swit...
51 Hornet Dash Switch
6 Users
(@Dean Prodromos)
My Club Coupe has a rotary switch mounted on the dash between the ignition switch and the cigar lighter. Its not presently wired to any circuit.
I can't find it on any schematic or picture of the dash layout which explains what it is. Does anyone have an idea what this switch should control? My best guess is the fog lamps. They are also present but not wired in.
Regards,
Dean Prodromos
Posted : 20/06/2016 8:19 pm
(@gjevne)
Honorable Member Registered
pictures would be helpful
Posted : 21/06/2016 3:25 am
(@tallent-r)
Noble Member Registered
Does it look like it was put there in the factory? That is, does the knob match all the other dashboard knobs? Is it placed in line with other switches, or just randomly? Are you saying that the photos you have seen of similar Hudson dashboards, don't have this switch?
It may have simply been put there by a former owner who was rigging up some accessory (like, as you say, the fog lamps).
Posted : 21/06/2016 4:28 am
(@Dean Prodromos)
Yup, it's original Hudson hardware as near as I can tell. It matches everything else on the dash.
Picture attached, I hope I did it right.
Dean
Posted : 21/06/2016 11:20 am
(@Scott Marshall)
That's your dash/park/headlight switch. I wouldn't do any night time driving if it's not connected to anything, unless someone has bypassed it and installed a separate switch to control those functions.
Posted : 21/06/2016 2:24 pm
(@aminard)
Estimable Member Registered
In 1951 the headlight switch was on the speedometer/clock cluster instead of one that lower panel beside the ignition switch.
Posted : 22/06/2016 1:24 am
(@m-patterson56)
Jerry,
And Hudson should have issued a recall (just kidding) for dash inserts with that switch location. You must reach up under the steering wheel, or (Not recommended) [i]through it[/i] to turn lights on/off. Same with wiper control.
What were they thinking?
Posted : 22/06/2016 4:55 am
(@aminard)
Well Frank, they did rectify the situation on the 1952 models
Posted : 22/06/2016 6:35 am
(@Dean Prodromos)
I looked at the 1952 wiring diagram and it identifies the switch on the dash as the main headlight switch. The one on the cluster is not identified.
My headlights do work. so I conclude the prior owner disconnected the fog lamps and used the fog lamp switch to operate the headlights, and disconnected everything from the headlight switch. Just ANOTHER REASON to completely rewire this puppy,
Thank you all for your comments. I'm heading to local show and shine if the weather permits. Its 101 today in Folsom. (But it's dry heat)
Dean
Posted : 22/06/2016 9:34 am
