I want to use a Hudson Autolite headlight relay from 40-41 Hudson because it looks correct. Can anyone suggest how much resistance should be added to the power to the relay coil to drop the voltage to avoid trouble. Or perhaps someone's experience is that the relay will hold up to 12 volts? Any experience out there?
Thanks,
Ivan
Posted : 18/03/2013 4:49 pm
