Jet Motor Oil
4 Users
(@awca12a)
Trusted Member Registered
I'm sure this has been discussed many times, but since I'm new to these Jets--What is the best oil and weight to use in the 202 Jet engines?
Posted : 18/03/2013 10:49 am
(@tallent-r)
Noble Member Registered
As far as I know the Jet engines are a modern-type (circa 1953) engine, and any modern oil should work. If the engine has not been overhauled in a long time, there are those who feel that a non-detergent oil should be used, because (it is felt) a detergent oil would loosen all the sludge in the engine and start to circulate it. In which case some of it could block smaller oil passages, leading to engine failure. However, there are others who say this is not true. So, go figure!
If you've acquired a Jet whose engine condition is unknown, it wouldn't be a bad idea drain the oil, remove the oil pan, and clean it out (and clean out the gunk within the engine as well) so you're starting out on the right foot with your new oil.
Posted : 18/03/2013 11:38 am
(@obermeier)
Honorable Member Registered
There is no real need to remove the sump from a Jet Motor, as the oil pick up floats and takes the oil from the top rather than from the bottom as in the earlier splash fed motors. Any good modern oil is usable in a Jet, but depending on the mileage and your climate whether you use a 15W-40 or a 20W-50. I have always used Havoline 20W-20 or Castrol GTX in my Jet, which I have now driven for 43 years.
Geoff
Posted : 19/03/2013 9:26 am
(@53jet)
Thats all well and good Geoff ,but what if we want long life out of the motor ? 😛
Roger
Posted : 19/03/2013 3:33 pm
(@obermeier)
I can't answer that. Check with me when I've been driving it for 60 years and I'll let you know if it worked! I'll only be 93 then. :whistle:
Posted : 19/03/2013 5:21 pm
(@awca12a)
Thank you, Jon and Geoff, for the responses. As usual Geoff-please add to my seemingly endless invoice! I sure hope I can ask you about my Essex and Jet when you make it to 93...
Joe
Posted : 20/03/2013 2:41 pm
(@53jet)
Geoff , thats an good point about the floating pickup missing all the crud
Roger
Posted : 23/03/2013 2:05 pm
