I have a spare water pump with a bad bearing, the seal is good. The factory manual says the shaft and bearing is to be replaced as a unit, the bearing is a Federal FS5158 any help in locating either one would be appreciated. Roger
Posted : 05/05/2016 3:43 am
Better to order a new rebuilt from Doug as you need special tools to rebuild. Walt.
Posted : 05/05/2016 5:57 am
