Fuel Gauge Ohms
Fuel Gauge Ohms
6 Users
(@Michael Monti-Colombi)
Can anyone help me?
Im restoring my 46 Big boy and have replaced the fuel/gas tank, i have to get a new gas sender unit for the tank but the company want to know how many ohms the dash fuel gauge is.
anyone out there know?
thanks
Posted : 20/04/2016 8:28 am
(@tallent-r)
Noble Member Registered
Discussion moved to "Hudson" forum category
Posted : 20/04/2016 9:15 am
(@jomoali)
Michael,
When I cleaned out the gas tank on a 1949 Commodore 8 I had to replace the sending unit in the gas tank. I found that the unit
used in 1948-1952 Ford pickups (6 volt) fits perfectly onto the gas tank. Its resistance is 73 ohms down to 10 ohms. It works properly with the original Hudson gauge. I just checked the C & G Ford website, where its price is $39.50.
Per
Posted : 20/04/2016 1:16 pm
Ok thanks for your help, ill look into it
Posted : 20/04/2016 10:04 pm
(@Jason Jellis)
Hello,
Would the 1948-1952 Ford pickup fuel sending unit also fit in a 1953 fuel tank?
Thanks.
Posted : 22/04/2016 3:16 am
(@jomoali)
Jason,
I believe that the gas tanks are the same through 1954. Someone is making replacement gas tanks for stepdowns, and I think he said that they are all the same. ( It would be good if someone who knows this for sure could let us know!)
Per
Posted : 22/04/2016 11:51 am
 BoJo
(@bojo)
Per
I have a 54 tank and earlier tank. The 54 gas tank is different because the filler neck is smaller in diameter and bent differently to come out on the earliier stepdown fender at a different location. No interchange possible unless filler necks are changed between 54 and earlier tanks. The 47 PU I bought had a stepdown tank already installed with altered filler neck. Don't know what was done to calibrate sender and gauge.
Lee O'Dell
Posted : 22/04/2016 1:10 pm
(@jomoali)
Lee,
Thanks for the information that 48 to 53 are the same tank.
Michael,
I am making the assumption that the mounting for the sender unit is the same for the 46 and 47 tanks as for the stepdown tanks (six threaded holes in a circular pattern). Ford listings show a similar sending unit which fits from 1936 to the end of the 6 volt Fords. Hopefully someone who knows the details can confirm this.
Per
Posted : 23/04/2016 1:30 pm
(@kholmes)
Per, those two screw hole patterns are indeed the same. I used a stepdown sender in my '47 for a while, and it fit perfectly (it didn't work well though . . . it was an experiment). And Michael, the '36-55 Ford sender is identical to the '36-'47 Hudsons. Both manufacturers got their gauge systems from the same company. So that's the one to use if your tank is a '47 or earlier. (You may have to play with the float arm elbow bend a little, but that's not difficult).
Posted : 24/04/2016 7:58 am
