Parts interchange
Parts interchange
4 Users
(@pfeifer)
Prominent Member Registered
Info for anyone that might need these numbers - I just installed radiator hoses and fan belt on the 37 PU.
Fan Belt -- Napa # 25-28463 made by Gates - 7/8" X 46-7/8"
Upper Radiator hose-- Napa # 632 flex gold 1-1/2" ID cut length to fit. Mine is 11" long.
Lower Radiator Hose -- Napa # 24226 1-5/8" ID Cut to fit, mine is 8" long. Both hoses made by Gates.
Hudson stepdown motor mounts- AMC square type with single post and interlocking plates--
NAPA # 6021162
Posted : 03/10/2012 5:48 am
(@kevinjets)
Make sure you have the coil spring inside the hose, for if not at speeds over 35 the hose will suck together and the engine will heat up. This is a problem a lot of Hudson owners are having. Splashers and Pressure engines must have the coil spring. There is a 3 piece lower hose advertised in the WTN, very good item. Walt.
Posted : 18/03/2014 4:18 pm
(@John Schulien)
have three 53 hornets... will carry spares
thanks, john schulien
Posted : 19/03/2014 1:52 pm
(@steve)
New Member Registered
Walt – I could not find the 3 piece lower hose advertised in WTN. What is the name of the vendor?
Jim Gerik
Posted : 20/03/2014 5:28 am
