Interesting head on...
Interesting head on a 1935 Terraplane
6 Users
(@arkiejazz)
Prominent Member Registered
Has anyone ever seen a head like this. It is in member John Martin's 1935 Terraplane.
Posted : 10/03/2013 2:53 pm
(@pacemaker51)
Estimable Member Registered
Have you considered asking Buzz Stahl?
Posted : 11/03/2013 2:23 am
(@35terraplane)
Appears to be ribbed and aluminum. Maybe some sort of high compression aftermarket racing head. Interesting that it says HUDSON on it.
AlexBurr
Memphis, TN
Posted : 11/03/2013 7:25 am
(@jstreich49)
Believe that is a standard head on the 35 Hudson. Not many Hudson 6cyl around. I have seen two, and I have a head like that in my collection of used heads. It is cast iron.
Fred "Ric" Pinder
Posted : 11/03/2013 10:11 am
(@jadebee)
There were several higher compression heads, aluminum lowers to disparate heat and a cast iron top with water jacket to keep aluminum head flat on block. A special gasket to seal the two head pieces. Water pump mounted on front of cast iron top section. Spark plugs mounted to the aluminum portion.
I have seen them for 1932, 1933,1934 and likely 35
Posted : 16/03/2013 11:05 am
(@jdick)
Eminent Member Registered
My dad had a 35 Terraplane two door sedan with a straight six that had an aluminum head that looked very similar to this one.I thought an aluminum head was standard on a 35 six cyl.
Mike
Posted : 19/03/2013 11:05 am
